454 oil pressure sending unit
Slooptin
Denver
Vance
k30
I'm in the process of doing head gaskets on my 454 and while I'm waiting on parts to arrive, I wanted to fix a problem I'm having with my oil pressure gauge. I don't think it's reading accurately, because with key on/engine off, the gauge shoots up to 30psi and with the engine on, it's pegged at 60. I'm thinking its a bad sending unit because the gauge will full sweep. My truck has the "fat" sending unit on it now, but I'm noticing there are two different styles of sending unit, a "fat" one and a smaller one that looks similar to what's on my jeep 4.0 motor. Both are 1 wire, but I'm wondering if there's a difference in voltage output between the two that might give inaccurate reading
Dave M
Banned
Australia
Dave
The left one is a straight switch for the oil light, the other for gauges. Sounds like a crook sender.
Camar068
Air Force Supporting Member
10 yrs Air Force
yeh it sucks some websites will get them backwards, or even the guy behind the counter will get it wrong.
With it reading 30 psi w/o the engine running, from my experience, its because someone put teflon tape over the input, very dirty oil, after an oil flush, or a bad signal to the gauge. I bet you could take yours out, spray/flood it with carb or break cleaner and let it sit/drain over night. Over the past 5 years I've changed 3 and 2 were after engine flushes, other was teflon. Worth a shot over a local $30 part.
I didn't change the last one after I did a seafoam flush on the block. The gauge went to 30 w/o engine on initially, but went back down after about 100 miles.
Slooptin
Denver
Vance
k30
Awesome, thanks
NateP350
