4" Leaf spring vs 4" shackle flip
MikeB
FYI, adding only dropped shackles or dropped hangers will change the drive line angle and move the axle a little forward (with hangers) or rearwards (with shackles). I did just the hangers and had to get my driveshaft shortened and then use pinion angle shims to tilt the nose of the pinion back down 4 degrees. Believe me, that was no fun. Had to make some longer spring locator pins to work with the shims. If I had a do-over, I'd opt for 2-inch "dropped" springs.
Mr. Gasket shock extension (left) shortened and machined to use as longer locator pin to accommodate pinion angle shim.
RoryH19
Rory
R10 Silverado SWB
Good to know if I ever change the height of my R10.
This is for my k5 (going up).
pgreensoup
