4 inch lift
Jozie85
Maine
Jozie
Where is the best place to get a 4 inch suspension lift for an 85 k10 , best price and quality
1973 Chevy
Wisconsin
1970Something
5.9 6BT Cummins
The 4" I got from Rough Country was pretty good all around. I got all new lifted springs, 6 shocks and boots, and sway bar drop brackets for $600. That's actually cheaper than their 2", also their 4" comes with the lifted steering arm, and all the bushings that you need. The one thing I didn't like about it was you need to find your own bolts that go through the rear shackle eyes and spring eyes, also the front of the front spring eyes. This kit comes with no bolts or nuts for the springs and shocks but it does have nuts for the ubolts. I thought the kit was a pretty decent price.
Swims350
Logan WV
none
our rough country kit was far cheaper, but it only had front springs, then it had rear blocks. Thus it had no u bolts and nuts front and rear, had to reuse the spring eye bolts though for the front, but ours was only lke $300 shipped. No need for sway bar drops unless you run 6 inch or bigger either, but we needed them because for some reason ours would not line up right, and barely did with the drops.
Scandia
