Kilian
- Mar 25, 2018
- Wisconsin
- K
- C2500 hopefully converting to K2500
I've found a 3.73 GM gear set that I'm hoping will work for my 14-bolt full float rear axle. Axle is on a 75 frame but not sure if it's original. Anyway, ring gear has 3992484 11 41 stamped on it. I'm pretty sure that this will work, but wanted to check with you experts before buying. Let me know if I need to get any other numbers off the axle. Thanks.
