TubeTruck
- Sep 4, 2019
- East TN
- Denis
- Suburban K10
- LQ9
I currently have a 31gal tank in my Suburban. I need a new tank, something is leaking from the top. I was thinking of installing the 40gal tank but when I check the measurements I'm not sure how it fits. My tank is sandwiched between to crossmembers. I can't go forward without hitting the rear axle, maybe backwards but I don't think there will be room to reinstall the crossmember. Has anyone done a tank swap/upgrade in a Suburban? All the research I find is using the 40gal tank in a pickup or a 31 in a Blazer.
My other thought was getting the '87 version since I'll be installing an L29 eventually with the correct pump for efi. Has anyone used this pump through a regulator for a carb? Just trying to avoid having to keep dropping the tank. I'd like to "one and done" if possible.
