3 Point Retractable Seat Belts From Pick A Part
73c20jim
Tombstone, AZ
I had threaded shoulder bolts holes also. One side went fine but the other side, the sheet metal hole did not line up with the threaded hole. so had to Dremel out the sheet metal, so the bolt would go in.
Mine came with a large assortment of mounting brackets and bolts. I needed the HD angle brackets from the assortment to mount the retractor. Both the retractor and the lap belt connected to the angle bracket.
I bought all new Grade 8 bolts washers and lock washers (needed 6 of different sizes) and was able to use all the stock threaded holes in the body.
I reused the middle seat lap belt.
I removed the seat to check the condition of the floor and to make installation easier.
Took two of us to install the seat, but you are probably much younger than I.
If it comes with instructions, read them twice before you start.
When I go out this morning I will take pictures.
Hope I covered it all.
73c20jim
Tombstone, AZ
I see hardware is extra. Get it just for the HD angle brackets.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
Thank you for the info. By the way, I am only 10 years younger, according to your info. Did you use the same belt or did you use from another site?. Was hoping not to have to remove seat as I do not have readily available help most of the time.
73c20jim
Tombstone, AZ
You can get to the end bolts by the doors, with little difficulty. The center bolts might prove problematic.
You might be able to take out seat and move it forward without removing it from car, or it might slide forward enough on tracks to get behind seat. OR you might have a fold back seat, in which case I will hate you.
I used different belts. Will check my invoices and report.
michaelmarine53
