2ND Aluminum Radiator Rotting out
85 CA SIERRA 1500
So. Cal
TRACEY
SIERRA CLASSIC
Hi Guys, as the title suggests, I am not having very good luck with all aluminum radiators.
I am on my 2nd one and it is rotting out where the core meets the end tanks.
Has anyone else had this problem?
What am I doing wrong?
I always keep it topped up with 50/50 antifreeze and distilled water.
The last one that rotted I took to a radiator shop to see if it could be fixed and they told me no and the reason that it went bad was because I had run only water when it started to leak. This time , even when the new radiator started to leak I made sure that I only put Distilled water mixed 50/50 with antifreeze.
Thanks in advance for any input/suggestions/ideas etc....
Tracey>>>>>>>>>>>>>>>>>>>>>>>>>>
I'm trying to remember but I cannot so I'll put this up and let others think research etc. I cannot remember all the consequences put I'm remembering something about AC ripple and ungrounded blocks turning the radiator and block into a battery with the antifreeze being the electrolyte. I would check for AC ripple and engine ground anyway. If I'm correct on my memory of this it turns your coolant acidic.
Carb'ed Vortec 350
Conditioner? It's needed with aluminum engines, may be needed for aluminum radiators too
Supporting Member Army
Pics? What do you mean by aluminum radiator? Is it one of the plastic end tank ones, or a "fancy" racing welded all aluminum one? What brand coolant are you using?
SquareRoot
Did you install an anode? Aluminum radiators need an anode otherwise your nice shiny aluminum radiator itself becomes the anode.
Curt
Loco Hills
Curt
K-30
What was the time frame that the 2nd radiator went bad?
Coolant definitely has a life expectancy.Not saying you reached that,but I’m curious.
I try and change the coolant every 2-3 years.I also use more of a 60% coolant 40% water mix.I use Prestone green.Tastes good.
You shouldn't need an anode unless something else is going on here. Head gasket leaking? Are you using tap water when you fill your radiator 50/50? Make sure you use distilled water and a good quality antifreeze. The corrosion inhibitors and the chemical makeup of the mixture should keep it from becoming an electrolytic compound. If exhaust gas is getting into the coolant or you are using acidic tapwater you will be making a battery and bad things will happen. Make sure everything is grounded well and that you are using a good quality coolant and distilled water only.
Oh you think that's funny do you? I used to touch my finger to a suspicious leak under a car and touch it to my tonque.Yep that's antifreeze, that's oil. Wait until you get battery acid, not evaporator water or coolant as expected.No more taste tastes.
Curt
Loco Hills
Curt
K-30
I do the same.That’s why I know it tastes good...no wonder the animals drink it.
SquareRoot
I disagree. Simple electrolysis will eat it up....unless everything in the cooling system is the same material. My all aluminum rad had noticable corrosion until I did some research and added an anode. Then again, I don't have ****** California water. Lol
Hey Curt what do you suppose a Zinc anode taste like? Wanna split one sometime?
Carb'ed Vortec 350
Peak doesn't taste sweet. I know by accident. I am not an antifreeze taste tester by trade...lol...
You wont have electrolysis if the block is properly grounded and the coolant is the right PH. That's why you NEED to use distilled water and a proper 50/50 mix of good quality coolant. Boats need to use an anode because they are using lake/ocean water for coolant which is a very good electrolyte. Modern LS truck engines are iron block, aluminum head, aluminum radiator, and brass fittings in various places. They have no anodes.
I have 185,000 miles on my 10 year old Suburban and just gave it the first coolant flush it's probably ever had. It has no anodes and had 0 visible corrosion in the aluminum radiator. The donor 1997 K2500 Suburban had an aluminum radiator and at 288,000 miles had no corrosion. It might also have to do with the series of aluminum being used in the fully welded radiators being a bit more sensitive to corrosion. Don't use tap water..... ever.
that_orange_c10
