K5 Blazer
- Jul 17, 2023
- Sant Cruz, CA
- Holden
- K5 Blazer
- 6.0L LS
I did an LS and 4L60e swap on my 4x4 K5 Blazer. I use a Holly terminator ECU. TC was a NP203 and I changed it out for a NP208. The NP208 and 4L60E is a nice option but creates problems as well. First I needed to install a VSS. I did install the Walter Engineering. I found Walter Engineering VSS problematic. First the signal was very weak and would only start working after I was going 20mph+. I needed to get the speed sensor closer to the reluctor wheel, so I sanded down the speed sensor holder to get it to sit closer to the reluctor wheel. It works better, now starts picking up vehicle speed around 4-5 mph but I would say's it's not perfect. Also where the VSS fits into the case is leaking oil and I need to figure out how to stop the leak. Possibly use some RTV where the o-ring seals in the case. Second issue, I am using a Dakota Digital gauge cluster. I wanted to use the factory gear selector that attached to the steering wheel, swapped it out for a 4 speed automatic instead of a 3 speed. The shift points will not line up correctly on the shift indicator. Tried several adjustments but can't get it to line up correctly on all the shift points. Probably going to install the Dakota Digital transmission selector but I really wanted to keep the stock look and feel of the original gear selector. Third issue, I am running 33" tires, my stock gear ratio was 3.07. Changed my gear ratio to 4.56.
