2 wheel th350 to 4wheel th350 conversion
00-dirt
ohio
Dustin
k-10
I Have a 74 chevy k-10 Auto. I call it frankentruck because everytime i go to fix something, i find a part that came from a different truck. That is what has actually led me here. My trans quit on me saturday. I have up to 20mph and then it s like it slips out of gear and revs to the moon. Upon further investigation i found the truck has a 700r4 and np208 tranfercase. The trans does not have a plug ran to it for the lock out and i dont know what else it has wrong lol. I am now going to throw a th350 in it and need to know if there are different size out put shafts for the 4x4 th350 trans. I know there are more than one size for the 2wd. Can anyone help a newby out. This is also my first full size and first 4x4 truck.
They are both 27 spline outputs. It's the th400 and SM465 that have the larger 32 spline output. You just need the short tail th350 and a fitzall (sp?) spacer to make it work with your current t-case. Might need to trim the output slightly. HRPC did the exact same swap, he knows exactly what needs done... hopefully he will chime in.
Swims350
Logan WV
none
if you can get the fitzall or even tci kit it comes with the correct length shaft for the inside and the spacer. mine did, but that's to make a short tail fit right in place of a 700r4, no driveshaft or crossmember mods, not moving forward or back or anything.
Todd Lemon
