2 350 same problem
84Distefano
New hampshire
Vincent
Hello,
Kinda stumped with my 84 C20. I had the original motor lodge a rod or two. stopped the motor dead. prior to this issue i noticed the oil pressure wasnt consistent and tended to be kinda low. never electrically irratic but it was run low. at 40-60(after being fully warmed) would hang around 30-40 psi but coming to a stop or at idle would hang around 10-15 psi. i swapped in another 350 and it is having a similiar problem only a little more severe. it drops off the oil gauge at stop now. at idle it sits between 9-12 psi. and seems to respond better under normal driving conditions, sitting somewhere around 40-45 usually. there is some "rapping/ticking/slapping" that sounds to me like valves but at idle sounds like rod knock a little. doesnt do the "rod knock" all the time just after a 30 minute drive. and only at idle. the other sound does it if i hold a constant rpm/speed. any ideas?
Thanks for your time.
nvrenuf
Mobile, Al.
What was the mileage of the first motor?
Was the 2nd motor new or used? If used, approx milage? Low oil pressure + internal noise tends to indicate it's a P.O.S..
Electrical or mechanical gauge? If electrical, verify readings with a cheap mechanical gauge.
Is there an oil cooler on the truck? I suppose it could be clogged causing oil flow issues.
But it does sound like you installed a worn out engine.
Yikes.
84Distefano
New hampshire
Vincent
first motor had around 121k and slowly lost pressure over a short period of time. and the second motor i was told had 8000 miles. seems like valve tick at first when holding constant speed. after running for 30 min or more and sitting at idle afterwards it has a low in decibel knock it seems.
84Distefano
New hampshire
Vincent
the gauge is the stock that came with the truck and stock sensor. i would imagine that it is the mechanical. it has a mechanical pump with a pressure switch.
dhamp
Atlanta Area, GA
Derek
R-10 Custom Deluxe
Can't really trust the stock oil gauge in the dash all the time. I can tap my dash 5x and get a different reading every time.
flynhigh88
