- May 13, 2019
- Oregon
- Eric
- K25
- 350-4bbl
That’s definitely not how that coolant sensor works. You are not going to get a useable coolant temp reading for your gauge from a 5v reference sensor. The 3 wire 5v reference and 1 wire resistive sensor work on completely different principals and won’t provide a usable signal to a gauge. You will have 5v power, ground, and ref on that 3 wire. The ref signal is a power output(from the sensor) that varies from 0-5v as the temperature changes and is read by the ECU. The gauge works by supplying power from the gauge, through the sensor(with varying resistance based on temperature) to ground. This means that with your gauge wire spliced to ref, not only are you not going to be providing a variable resistance to ground, but you will be pushing 12v through your 5v ref signal wire and could quite possibly smoke your ECU or sensor(since it is only designed to handle 5v).You could have tapped into the green wire on your 3 wire for your temp gauge same as I could have run 1 extra wire to the front and swapped my 2 wire for a 4 wire firebird sensor. It was just easier to separate them as the gauge wire was already in the right spot (pass rear) so im using the firebird sensor and plug but only the center pin on it. The center pin or green wire is the resistance wire. The other two require 5v reference and signal return for the ecm. After attempting to remove the factory oil pressure sensor I decided to leave that pain in the butt in there and run the factory one off the oil filter plate same as the rest of the saine people on here.
Did all the interior wiring today. Really didn't want to pull the dash but I caved. So after a full day in mostly awkward positions and fixing alot of unrelated wiring from the PO, I can safely say the inside is done...well, I still gotta put the dash back together.
your gauge would also be seeing the circuit as an open at the same time, which would mean it would be locked on cold. The ECU would be seeing the same thing, since the voltage would always be 12v, so if it doesn’t blow, it’s going to at-best throw a sensor voltage circuit code and at worst just think it is always freezing cold without throwing a code.
The way the 2 wire circuit is designed is different, and you could probably get away with a splice, as long as you diode protect the ECU circuit so that you aren’t feeding 12v back to the ECU. I still doubt the 2 wire sensor would provide a correct resistance profile to match the gauge though.
