1989 R2500 to early grille swap.
awallspdx
Beaverton OR
Adam
C20 R25
So I have a ‘89 R2500 (C20) crewcab but I’m not a fan of the grille. What would it take to swap to a ‘83-85 or a ‘86-87 grille? Just not a fan of the “newer” look. Can I just Gina grille and light buckets and re wire or do I need more?
Thanks! I’m new to square bodies.
Vbb199
B-rate Hillbilly Customs
Salisbury NC
Vince
89 Suburban R1500, 79 C10
Rad support,grill, lamps, harness, trim.
Fenders and hood stay.
awallspdx
Beaverton OR
Adam
C20 R25
I’d the rad support different? I only see two listed, single and dual ‘81-‘87
Was the ‘88-‘91 rad support really different since they are actually square bodies and I have to search out different years to actually find parts.
Thanks again
Man... that grille just looks so good with the US Forest Service green paint though...
RecklessWOT
New Hampshire
Kevin
V10 Suburban Silverado
I agree, the newer "modern" grilles that were slapped on the '89-91 squares to try to make them look more like the GMT400 pickups that were out at the time look very out of place and cheesy to me. '83-'84 stacked light grilles look the best IMO, though the '85-'87 grilles still look much better than the later ones. I know the rad support is different on the round eye trucks, I wasn't aware of there being a change post '88 though it doesn't surprise me, totally different grille style probably had different provisions for mounting and trim and lights. I would assume it would be easy to rig something up without swapping the whole support, but honestly that's just a wild guess. Doesn't appear to be like a show quality truck or anything so even if zip-ties or self tappers were involved or something I bet you could easily get an older grille on there as the rest of the sheet metal is the same.
awallspdx
Beaverton OR
Adam
C20 R25
what do you mean it’s not a show truck?!? JK. Yeah it will get used for what it is. Good call on the self tappers. I’ll be on the look out for a decent deal on the parts needed for a ‘83-‘84 or anything up to ‘87. I like the idea of having the center stripe paint matched ( assume this was a Silverado trim level thing)
Shak379
