1987 c-10
Cdnss454
Canada
Peter
Silverado c10
I have a 1987 silverado c-10 and I want to change out the grille and headlights to a 1986. Right now it has the 2 small headlights above the signal light.
Can this be done without changing the rad support etc.?
Thanks Peter.
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Are you saying you want to go from single to dual? You're gonna need to swap core supports if that's the case.
Cdnss454
Canada
Peter
Silverado c10
87 c-10
No I want the stacked headlights with the square signal light on either side.
Cdnss454
Canada
Peter
Silverado c10
First pic is my truck second is what I'm looking for.
animal
Moderator
Lee
c10 silverado
350ish
You will have to change the core support to go to the "mini-quad" setup that you are wanting.
Opps I looked at the pics in the wrong order. You already have the mini-quad setup. Yes you will have to change the core support to go back to the original lights.
Cdnss454
Canada
Peter
Silverado c10
Thanks. Is the grille set up I have right now common for 87?
animal
Moderator
Lee
c10 silverado
350ish
Pretty common mod that a lot of folks do. It's from the 88-91 suburban, blazer, and ton trucks.
RangRayy
Kansas City, Missouri
ryan
r10
My '87 has the dual lights on top of each other and the grill is like the second picture. I always thought the side by side lights were years '88-95. ??
animal
Moderator
Lee
c10 silverado
350ish
They only ran the "square" body style thru 91 on the suburban. blazer, and ton truck. The GMT 400 did run a little longer
RangRayy
ryan
r10
Gotcha I wasn't sure how far into the 90s they ran dual lights side by side. My '95 Silverado has the side by side but looks nothing like my square obviously lol.
UNCLECHAD2021
