1983 K10 Frame
tx_truckin
Fort Worth
Jason
Does anyone know if the frame on a 1983 K10 is the same as a K20 and just the axles are different.
I'm new to the Forum and to the truck.
towman
harrisburg pa
jay
v10
frame and drive train are both differant
GreaseDog
Elkhart, IN
1977 K20
1980 K2500
the frame is identical to a like year K20, the only difference is the front 8 lug hubs, and the 14 bolt rear. 73-80 10 and 20 frames are interchangable, and 81-87s 10 and 20 frames are interchangable.
towman
harrisburg pa
jay
v10
grease dog is correct, got my facts mixed up on that one
Moderator
I will add though, the frame rail thickness is slightly different between the two... and it varied through the years and also changed between 2wd and 4x4. I doubt you could ever tell a difference by driving them though.
tx_truckin
Fort Worth
Jason
1983 k10
So if I had a 1983 k10 and the axles and springs were changed out to the
3/4 ton axles and springs its basically a k20 at heart but not by VIN number
nvrenuf
Mobile, Al.
yep
Moderator Administrator
I don't think I need to add, but just to make myself look important..... :lol:
All info above is correct including buckets info about the frame rail thickness. I looked into this when pops was wanting a K20 and wouldn't settle for a K10. All springs will interchange, and axles etc at GreaseDog and Towman said. If memory serves, the frame thickness on the K20 was 1/16 thicker, and the flanges of the rails were 1/8 in deeper. Both are made of the same lb test carbon steel also.
I also have a 85K10 I fully intend to put the 3/4 springs under and run the 3/4 ton axles.
I have a feeling the K10 frame will be better for articulaiton too, and being the square body trucks don't have a common problem of bending frames like the GMT400 trucks do, I think its a great combination. On my 85 K10, I am recabbing it with an 85 C20 cab.
If you're doing a cab swap, remember you'll need the hump out of the K10 cab. Its a higher hump to allow for the Tcase. I will have to cut out my C20 hump and weld in the K10 hump for my project. :grd:
tx_truckin
Fort Worth
Jason
1983 k10
Thank you for all your answers, they are all much appreciated. When I get my new/old 1983 Chevrolet K10/K20 home I will add pics.
For Certain. Truck Porn is not only encouraged here its required.
BTW, Welcome Aboard GMSB.
old yeller
