1979 C-10
Mark Jones
Horse Shoe Bay Tx/Thousand Oaks Ca
Mark
I finally got my 327 installed in my 1979 C-10 big ten. Hoping to get the drag strip next week and I have a few questions for the experts.
1. 350 non air, turbo 350, 12 bolt open rear end, typically what gears could this truck have?
2. Does anyone make light weight drag race wheels for this 5 lug truck, I want 15X3.5 on the front, and 15X10 on the rear?
1987 GMC Jimmy
Automobile Hoarder
Mississippi
Jesse
V1500 Jimmy
Check your SPID label in the glovebox. The gearing code is something like GU*. That’ll tell you what it came with originally, but that may not be what it has now.
Mark Jones
Mark
That sticker is gone. Surprising the truck was fairly virgin, and the rear end is original, I do plan to build another rear rear end for the truck, and then I can call it done. I just hope theres not 3.08s in there, which will be counter productive to the 13 sec time slip I would like to see.
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I’m curious why you decided on a 327?
78C10BigTen
pennsylvannia
C10 BIG TEN
My 78 big 10 with a 350/th350 and 12 bolt (used to be posi) was a factory 3.08. It is now a 10 bolt 3.42 posi...
Mark Jones
Mark
Good question: Because we were in the middle of building my sons 302 and had bought several virgin 327 core engines, I DO NOT like nice virgin GM engine cores to go to waste, or just sit around and never do anything with them, and I wanted my 14 year old son to understand what its like to build something out of old discarded parts most people would never use. Now was it a good idea to use a 327 for a performance truck build-not so much, but the truck is cool!
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Mr. Jones is pretty well known for making power. Lots of BBC Chevy powered hot rods with engines built by him. And several informative YouTube videos if do search.
Good luck on the build!
I checked out the video. Looks like a healthy amount of tq from the 327. I have one in my garage. I think I’ll borrow his specs some day.
Mark Jones
Mark
I was able to weigh my 1979 C-10, with no driver it weighed 4040 pounds, big ten long bed, turbo 350, iron headed small block, factory wheels, no air conditioning. It also has the 3.07 rear gear.
roundhouse
atlanta ga
justin
77,78,79,80 ?
327 can be a pretty good drag engine
They spin up to high rpm quickly
My brother had a built one in a 76 4wd
Remove the lake pipe covers to Uncork the headers , put it in 4-low and best a corvette or mustang
That's some damn good reasoning right there :)
my 78 1/2 ton BUT K10 has 3.73 if the front diff tag is to be believed, the label doesnt say unless im missing it
theshawnR
