1977 gmc k25 ignition cylinder siezed.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Ok I my 77 k25, is stuck in the run position and I cant get it to the star position or the lock position. I have the new cylinder but the old one just wont come out. What do I do?
chengny
You're lucky because that's were it has to be - to remove the lock cylinder:
Looks like the steps are:
1. Pull the steering wheel
2. Remove the directional switch
3. Remove lock cylinder
All the pertinent pages from the 1977 service manual are below.
Steering wheel R & R:
Directional switch (NOTE - last part of DS install is on the first page of LC removal):
Lock cylinder:
ruedger455
three rivers , mi
kimber
k2500 grande sierra
I literally have destroyed the old cylinder! No internals at all just the shell. And it stoll will not come out.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Heres my aftermath.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Is there anyone that can help me out??
chengny
Did you complete the preliminary procedures as posted above?
The cylinder can't be released unless the steering wheel and directional switch are out of the way.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Yes ive got everything apart and it still wouldnt come out, so I blew out the internals with a hammer and a screw driver.I gradually pulled the internals out piece by piece. And it still wont release.
chengny
IDK - to offer any more help, I'd have to be there.
Here I found this;
Well I got the switch out with the advise of an older white man that said that when the car has the original switch from the dealership, there will no way to push the retainer clip that allows the switch to be pulled out. I had to break a piece about a quater of an inch by the thickness of a dime of the soft thin pot metal that hides the retainer clip. Once I pushed the clip out the switch, it slid right out with no problem. I guess no one had ever replaced the switch on the car before
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Thats what im going to try today. This whole thing is so frustrating.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Got it all out and got the new one In, and what do you know? It didnt work, the new cylinder locked into the lock position and now it wont engage. I can just turn it from lock to run, and it just stays in the lock position. This is very frustrating.
chengny
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Im trying to flow everything step by step to get the new ignition cylinder out and it wont come out either.
chengny
At this point, it probably would have been faster if you had gone to the junkyard, pulled an entire column, brought it home and replaced yours.
They usually only go for about $50 -75. That's from the rag joint up to and including the steering wheel.
ruedger455
three rivers , mi
kimber
k2500 grande sierra
Yea I just said screw it and sent off to the mechanic.
circuitguy
Elk Grove, CA
BIG-C
GMC 1/2 ton Stepside
Bad ignition switch on the back of the column or a stuck ignition rod???
whythoughs
