14 bolt lengths
chevydude
arizona
hunt
k20
Hello i was looking at the two 14 bolts. Is there different lengths. and are they supposed to be shorter than the front.
Thanks
towjoe
Lafayette,IN
joe
78,80,81,81,86,88,89
K30's or V3500's
axle shafts are the same part # 3/4 ton to cab and chassis dually according to hollander book so difference must be in hub offset
chevydude
arizona
hunt
k20
Well I know that Chevy started to make the back shorter than the front for better steering.
Im just trying to find out which one I have because 1 ton axles were not shorter so The 14 bolt bible will help thanks.
towjoe
Lafayette,IN
joe
K30's or V3500's
One ton cab and chassis had the backing plate right against the springs. It's a chore to get in to bleed the brakes on them. Single wheel ones had ample room to get in there to bleed brakes.
cmritz
