10 or 12 wides?
Eli28
usa
Eli
I’m looking for a setup like the picture below.
What wheel and tire size would you recommend for a 4” lift.
Those rims are probably only 8 inches wide, but have very little backspacing. Notice how much of the brake drum is visible.
Also with only 4 inches of lift, you're going to need rusty fenders to steer that, or trim the fenders if they aren't rusted away.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
If you drive in the snow and mud get skinnys. I've haven't had much luck with wider tires for 4x4s.
Eli28
usa
Eli
Do you think I could fit 12 wide with 63mm off set and 15” or 16” rims on 33s or 35s on a small body lift or going to 6” suspension?
Eli28
usa
Eli
What kind of sizing would get some slight poke but not mall crawler maybe a happy medium between these.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
The front ends poke with stock everything with rally wheels, so anything more dished or wider will poke a lot. The rears don't poke unless you've got wide wheels or spacers. Front compared to back axle track width is 3 inches, 1.5 inches on each side.
Ive never rubbed on 4 inch suspension and 1 inch body lift. 33x12.50 or 35x12.50 15's.
You'd be safe with 33's on a 4 inch on stock or similar spec wheels.
Auburn, Washington
No.
True 35s (IE new mud tires) barely don’t rub on a 5” K20 lift with 20x9 at 4” BS.
If you’re looking to actually fit a big tire and positive offset wheel on the front of a square without an abnormally large lift compared to what you’d expect, you need to relocate the front axle forward.
6” lift on a K10 with brodozer mall crawler rims and 35s I’d estimate will barely work but better not hit a bump with the wheels turned or it’ll rub.
EDNOMAD
