10 bolt front axle identification
whiplashcolo
Colorado
Steve
k30, blazer
Does anyone know if gm 10 bolt front axles are stamped with a code or anything that would tell the gear ratio?
rpcraft
Robert
LS 6.0 364 CID
NO. It was usually on a stamp on a metal tag that was on the cover plate (depending on the years but after a certain year it was only on the build tag for the vehicle) I believe. No time like the present to get some fluid and a gasket and count though. The gearing is stamped on the ring gear when you spin it around. I guess if maybe you have one of those tiny endoscope cameras you might be able to poke it in the cover and rotate the pinion and see (not sure on that approach). FWIW, fresh gear oil is good for them if you have never been in there during ownership.
Also, if your vehicles are pre 1978 chances are you have a dana 44 though and not a 10 bolt (just looking at your user ID info) unless someone has changed them out.
Charlie
Euless, Texas
Don
Cheyenne 10 LWB
350/TH350/AC/4 BBL Quadrajet
:welcome:
Brian J
Arkansas
K5 Blazer
:welcome:
shiftpro
BC Canada
shiftpro
350, 383, 454, 496!
Send us a pic, we're all fukin experts here...
that_orange_c10
