04 Buick Rainier
custodian
Catawba
William
C10, C30
5.3 LS, 350, 454
I'm selling my Buick since I found a Silverado that I want to buy. I have fixed it to drive and have put almost 2000 miles on it since I've had it.
2004 Buick Rainier CXL 2WD
$2,900 306,000 Miles
This vehicle is not perfect. Clear NC title in my name
LM4 all aluminum 5.3 V8 , 2wd 4l60e AT, 3.73 limited slip rear end, cruise control, delay wipers, full gauges with tach, tilt wheel, AC, PS, PB, PW, PDL, PM.
THE FOLLOWING PARTS ARE NEW: front and rear disc brakes and rotors, water pump, cooling fan clutch, power steering pump, rear spring conversion, rear shocks, upper control arm on drivers side, bearing hub assembly on drivers and passenger side, exhaust from muffler back, ac line switches, oil pressure sending unit, gas cap, drivers and passenger side tie rod (passenger side has not been installed), valve cover gaskets (have, but not installed). Needs blend door motors replaced (have, but not installed).
Power and heated front leather seats, AC doesn’t work, rear AC controls, working DVD player with 2 sets of head phones, rear radio controls, ABS light on, passed recent inspection, miles will go up as I drive it.
NEEDS: Front knock senor and Purge valve,
mick84
