78C10BigTen
pennsylvannia
C10 BIG TEN
You keep dumping gas on the ground like that, you'll be money ahead getting a new tank, after a few times of that!
Tanks are pretty cheap in reality.
Plus i need to patch it until i get one, as its my only set of wheels. I cant afford it down.
Temporary and easy. I'm assuming you have a 2 port pump, Put an air bubble,old compressor tank etc. In the bed. Put a fitting where the drain was,drill 1 hole in the bed run a hose down to the fuel line. Use the air bubble as a temporary gas tank. This is assuming you dint drive far daily,other wise you'll need a compressor tank. A propane tank would work also with more work. I've even used an old R12 tank in the past. Cheaper and less risky than dumping fuel on the ground every night.
78C10BigTen
pennsylvannia
C10 BIG TEN
Well to clarify this isnt my square, its my daily 91' s10
legopnuematic
Licensed Junk Dealer
MO
Spencer
Went to an estate sale and got a Delta overarm router/shaper and another HD shaper. The router I don't believe has ever been used, its still bolted on the original shipping skid.
Got it down into my shop
Came with the manual and accessories/tools
1/2 spindle for shaper cutters and 1/2 to 1/4 collet, wrenches
Spindles and knife heads for the shaper
The router was what I was really after, I'll need to evaluate the shaper and see what I want to do with it, as I already have one.
skysurfer
west coast
1989 Suburban
V2500
5.7/TH400/NP241C
Saw this sitting on a garbage can while driving home. I don’t need it but at that price I couldn’t let it go. Other than the lid being a little sun faded it’s in good shape. Measures 20.5”x 12”h x 9”d. I’ll put it on Craigslist for $30 and see if I get any nibbles.
chief_shotts
beaverton, OR
edgar
k30
I’ve got two of these. One I bought new and one from my grandfather. Good tool box that won’t break the bank.
legopnuematic
MO
Spencer
Got a paint gun light
Seems like a nice piece.
legopnuematic
MO
Spencer
Got this ferrule Crimper and ferrule assortment. About $11 for both.
waterpirate
delaware
v10
5.7 tbi
I borrowed a buddys Millwakee multi tool to take for a spin on my kitchen window replacement. 65 year old crown molding may be a trick to replace. I am hoping the multi tool makes putting it back a reality.
1STLS1
West Phoenix AZ
MIchael
Won another local online auction for carbon pile battery and charging system testers. A little dated, but for $72 for both, not a bad deal. The amp clamp on the one makes it very useful chasing draws and finding junk starters that are still working but drawing too many amps.
Doppleganger
OH-MI: Just like it sounds
Not sure if this counts, but I've been in need of some tool drawers (for shtuff like taps, thread chasers, specialty sets, etc). Other than marketplace drawer slides and Dollar Tree pulls, this was made from 100% scraps. My budget was "as close to free as possible". Norm Abrams wont feel threatened but they're functional.
Stupid stuff like this really frees up bench and wall/pegboard space.
You know,to pull the nails through,or clip them off on the backside? Right. Don't try to pull them out the front.
grego28
