Source for rear AC fittings?
v30
Yokosuka
Billy
V30
When I had my new A/C hoses built they found that GM used a larger diameter hose fitting than normal for the evaporator connection, probably because the orifice tube fits in there. The A/C shop just took two fittings of the right size, cut them apart and braised them back together to make an adapter, and then crimped it on the new hose. Only took him a few minutes.
Matthy71
