Let me tickle your brains about stall issue.
cbrown5385
Mass
Corey
Suburban 1500
My 86 k10 has developed a stalling issue. When I start it up and warm it up then go into drive and move it a little bit then go into reverse it stalls out, I can restart but then the idle kicks up and almost stays in high idle and it takes me a few blips of the throttle for it to come down and if I don’t do that I have to stand on the breaks to keep it stopped until I get the idle down.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
How long do you warm it up? Choke needs adjusted.
fast 99
Spokane, Washington
Besides choke, there should be 2 choke pull-offs that can be adjusted. When a carb is rebuilt there are base settings however every engine is different. Most times a little tweaking is needed.
Sad Sack
Omaha, NE
Goober
C15
I recall something about fast idle solenoids having issues.
metro247
