Center/carrier bearing orientation - 76 C20 suburban
legopnuematic
Licensed Junk Dealer
MO
Spencer
Try here: Denny's Driveshaft
Going to need to measure what the thread diameter is and such, then go from there.
Tyger13us
BFE,Ut
Jeff
450hp/357cid
high or low on the center carrier bearing depends,,
You want the primary drive line as straight parallel with the trans/transfer case as possible.
ive seen um up, but the mount of the trans to cross member was shimmed to be straight.
off Roaders what them UP so they dont get hung up on Stuff..
but thats all factory stuff......
you want the front crank shaft degree straight with the end of the primary drive line center.
TheC5Surgeon
Panhandle of FL
Matthew
ok so i got a new bearing cause i damaged the other a little on disassembly. It came with a little spacer but no removable covers like the last one. No instructions for install in either. Should I just install the more open side towards the front where there is a little dust cover built into the driveshaft then that portion with the rubber grommet installed towards the back? Looks to me like dirt and grime will still get into the bearing regardless.
ali_c20
Austria
Alexander
C20, K5
The bearings in the carriers are often sealed ones or have a dust shield around them in the rubber and are greased.
I think the side with the thick rubber on the second picture should look toward the transmission. Facing the driving direction more dirt and water is thrown to this side.
TheC5Surgeon
Panhandle of FL
Matthew
There seems to be a built-in little shield on the drive shaft right in front of where the bearing sits. There is nothing towards the rear. I will send a picture of it later today.
ali_c20
Austria
Alexander
C20, K5
Dspec
