edelbrock fuel line leak. Anyone else?
spedigo
texas
Sam
big10
just reworked my fuel system and part of that was putting a brand new Edelbrock 8126 fuel inlet onto my carburetor.
Pretty sure it’s leaking from the banjo fitting. I’ve got both of the provided washers on either side. I’ve got it tight, but not Hulk tight. Anybody else have this problem?
Edelbrock
Earth
Grumba
K5 Blazer
With a banjo, try to find softer washers. Brass, aluminum or what ever is the easiest to deform under pressure. Then all you can do is tighten more, and check for leaks. Tighten more, and check for leaks, and repeat. Even when they seem like they are going to break or strip, all you can do is keep cranking away or trying different washers.
spedigo
texas
Sam
big10
anybody know the exact size of those particular crush washers? (Shop my truck is in is out in the country. Kind of need to have all my stuff together before I head out there.)
Tonimus
Phoenix
Tony
C10 Suburban
^This. Copper is the way to go. Plastic will always eventually leak. I had the same exact issue.
clee
