whats every body using.. looking for a new stereo head unit
Thanks for posting that picture. I was looking at them or Retro Sound. If there is no option to dim that display then I will find something else.
@totallyhucked Not sure which model radio you have but see the instructions, page 11, for Custom Autosound radio. It shows there are 7 brightness levels. Instructions
Admittedly, mine was an older model. Idk how old, it was in the truck when I bought it but I had the book and there was no adjustment for this one. It was the Concours Series USA-230 (I'm actually looking at the book now lol, my buddy that bought it from me forgot to grab the book). Our shop truck has the same one in it, no option for brightness adjustment
Camar068
10 yrs Air Force
Well, I could use some advice for my 90 Crew...I just want it clear sounding and simple.
My thoughts:
Retro 1.5 din in dash. No cutting needed since it's a 90
6x9's in rear corners.
5" or 4x6 in each door(4 total)
3.5 in front corners
1-2 of those self powered retro sound subs under rear seats
Is that too many speakers?
Do I need an amp, what kind?
What about a center speaker?
I've tried crutch fields catalog but it only recommended 4 speakers total and local stereo shops want me to spend $10k and install a bunch of subs
I'd start with 4 at the corners and go from there. With it being a crew, just adjust the front/rear balance to you being in the drivers seat.
My thoughts:
Most head units have 4 amplified outputs designed to have 1x8 ohm or 1x4ohm load if you wire two speakers to the same channel it can be the wrong load and burn up the output. Example say you are supposed to have a channel with 1x4ohm load if you wired two 4ohm speakers in series you'd have an 8 ohm load which is wrong. If you wire two 4ohm speakers in parallel you'd have a 2 ohm load,again wrong. If you wired 2x 8ohm speakers in series it would a 16ohm load.But if you wired two 8ohm speakers in parallel it would be an 4ohm load which would be acceptable. To answer your question,ya it's doable,kind of a wiring challenge,center speaker for all practical purposes would be a no,possible but a big hassle. Your sub would have to be amplified. Your other speakers could be run off the head unit
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
Agreed. To enhance the sound quality you can run a complete component set in the front left and right.
Finkaire
Finkaire
California
Loren
Silverado c10
Retro-sounds, couldn’t be happier. Plug and play, no holes, simple controls looks OE. Added a JBL under seat sub-woofer to complement the speakers. Crutchfield adapter, no cutting or splicing. Sub-woofer plugs right into the head unit and powered up from the cigarette lighter. Bluetooth makes a huge difference in driving experience. No thump thump, just great sound!
Camar068
10 yrs Air Force
I love JBL. Of course I'm biased 'cuz my mom was a sales rep at the Bamberg Germany PX in 1982 and won sales rep of the year so they gave her a set of JBL L112's (which I have). I've cranked them bad boys up with underrated/average receivers over the years.....no complaints from 13 years old to today. So I stick with them.
Edelbrock
Earth
Grumba
K5 Blazer
Old school is always an option.
j69shep
Scottsdale, AZ
jim
Keep it stock. Send your radio to me and I''ll fix it and add one button bluetooth. The Delco 2700 is a fine radio with plenty of power and it fits like a glove and drives 4 speakers. Still plenty of parts available to keep them running for years. I have 5 good ones in stock right now. Call or text me at 480-235-1964for details.Repair time is running 7-10 days. Thanks
Spider
Montana
GMC and Chevy v2500 suburbans
5.7 tbi, 6.0
Went with retro sounds. Works decent, fit was less than perfect. Not sure how they screwed up a simple rectangle. Mounting hardware was useless. Wiring was painless. For the price, I expected it to actually screw into something with the supplied parts.
It’s a one size fits all head unit with a face that’s supposed to be for your specific vehicle. It just plugs in and screws on to the head unit
geolee
illinois
george
Anyone know where to get a factory wiring harness? When i got my truck the guy cut it and wired it up to save money. The whole truck was like that. I haven't had a radio in there for a long time
CountKrunk
SW VA
Count
C20 Custom Deluxe 3+3
v8 350
Painless has been used a lot on the forum. Search you'll get a lot of results.
Dont think you can get a "factory" harness beyond finding one that's in better shape than yours but then it's still 40 years old.
j69shep
Scottsdale, AZ
jim
By factory harness are you referring to the 3 plug set that plug into the back of the radio? If so I have a set and I have the radio too in perfect working condition with bluetooth. Jim 4802351964 call or text
Nodakr68
South Dakota
Clay
K30 Scottsdale Dually
I went old school in my dually, all of it is time period Alpine.....including cassette deck with dial radio and push button to set the stations !! It took me a while to find it all, including Amp and 6x9s, but they are all period to my truck !! Here's a pic of the little test run of the deck, I did just to make sure it worked, before I installed it !!
kgc4160
wahington
kelly
METRA 70-1677.. FOR 78 TO 91 GM RADIOS.. BOUGHT MINE FROM AMAZON.. 7 DOLLARS
His factory plugs are cut off,he needs a dash harness for his truck
Corneel
