Another leaf spring question: (plastic shims).
Toad455
North Texas
Kevin
I posted a question a while back about these plastic shims but that was before I took my springs apart. Now I see there is a hole on each end of one of the leafs that had a plastic shim that snapped in place. The pass side had the little plastic nub broke off so the shim scooted away from the end, there is wear on the spring from them rubbing together. The drivers side doesn't have the wear since the plastic shim is still attached. This is on a 78 C10 Scottsdale that has never been took apart before, I've known the truck since new. Any ideas on where to get new shims like these? I've looked at LMC and every other place I know and found nothing. Without the nub they won't stay in place. May be fine without them but there is a little wear where the shim slipped off.
Toad455
North Texas
Kevin
Well, I dug around more and found a site "General Spring". Search "leaf springs", then "leaf spring parts", then "tip inserts". They have round, square, and rectangle shims. They have one that looks exactly like mine with the same oval hole. A few other sites have them also but they are hard to find since you have to search specific names such as Button Slider, Leaf Spring Tip Insert, Squeak Pads.
cadillac_al
Maine
Alan
Great tip. I have had those fall out before and never knew where to get replacements. Same with the clamps. I'll bet General Spring has the clamps too.
Toad455
North Texas
Kevin
Thanks, they prob do. This is the only place I found the sliders with the "button". After blasting I found a lot of wear on all four of the springs that I thought were perfect, especially on the one where the slider slid out. They sell the replacement spring packs reasonable, I may go that route.
I dont have a ready picture of the hole they stick in , but heres a blurry picture of the gmt800 ones on my 2500hd
WFO
Texas Panhandle
I tried and tried, but never could get to those tip inserts.
Toad455
North Texas
Kevin
  • Like
Reactions: WFO
vr1967
Mississippi
Virgil
k1500
6.2L turbo
Toad455
North Texas
Kevin
Shop around by pn I used the pn D-58 from KC Spring (not sure d-58 is what you need, just used it as an example)
And found them alot cheaper here
I have ordered from both places before
I got from General Spring: 2.99Ea
2 × 2-1/2" Wide, Square Leaf Spring Tip Insert with Offset Oval Button​
75 Chevy SWB 4x4
NE Oregon
Doug
K10 4x4
General Spring has been around for quite a long time. I wouldn't hesitate to buy replacement springs or spring components from them.
clee
