Np208 oil seal
Gussie
Kansas
Corey
Hello gang;
I'm rebuilding my np208 and when removing the oil seal for the transmission to transfer case I had two 19236 oil seals in there. Is this factory? Should this just be one thicker oil seal?
Thanks
Strick
Dunn, NC
Harold
C20 Crew
Putting them back to back keeps the fluids in the trans & case separated. The factory seals are usually a double or 2-way style. Back to back works fine tho.
HS
Gussie
Kansas
Corey
Hello, another question on this np208. There are 3 washers/rings?..on the shaft but I didn't see how these were spaced before the needle bearings spilled out. Is there a spacing to these 3 rings or do they all stack up on the end near that sprocket, thanks
630erik1
