mibars
- May 13, 2023
- Nadarzyn, Poland
- Michal
- Suburban V1500
- 350 TBI
I'm planning on installing a diesel heater in my Burb, that kind that looks like a dry Webasto, but made out of chinesium. The idea is to add heating in the rear for camping.
These kind of heaters are meant to be installed inside, on a mounting plate where just the intake exhaust and a fuel line stay on the outside of vehicle. It is possible to have them mounted outside, but they must be shielded from elements.
I want to install it in a way it interferes the least with interior. In campers and vandals they are usually mounted under seats, but in case of Suburban there is not enough space under them.
I figured out that possibly the best spot is inside a rear fender, there is enough room to fit the heater, that space is somewhat inside of a vehicle, even if not in a cabin space, but it will mean cutting a large access hatch on the inside and drilling some holes through the outer skin under the car for air intake and exhaust.
I live in Poland where cars do rust, roads are salted, like it's northern US.
I'm not a bodywork expert and I want to do these holes and cuts right, so I won't create rust issues. Any hints on that how to do it correctly? How to protect these holes? Exhaust pipe gets hot so I can't just silicone the opening to stop any moisture and dirt going inside fender.
