plugugly
- Oct 6, 2023
- rocklin, ca
- Damon
- blazer
- 6.2 diesel
SO i have spent hours trying to figure out why these damn gauges dont work. I have verified all gauges work individually, sourced a new resistor for the volt meter, check continutiy to grounds, etc, etc. Was expecting things to work today when I plugged it together and Nope, nada nothing.
So I checked continuity on the circuit pad itself. It seems to check out, so I start checking continuity for on the 3 pink/black wires that are ignition power to the circuit pad, and i seem to be getting resistance through them. There is power at the fuse panel(12 volts) but when it gets to the plug for the back of the gauge cluster, the 3 different ignition powers are all .12 volts. Im guessing this is why my voltmeter, oil press and water temp arent working?
this is the diagram I am working from
hoping someone konws what the hell is going on before I light this thing on fire.
