Oil filter part number
midwest
Indiana
Scott
My truck has a 1977 350 in it. I am planning to switch to WIX or NAPA Gold oil filter. Anyone have the part number handy for either of those filters. Last oil change I did, I was in a pinch and Fram was the only option. Never been a fan of those.
Finkaire
Finkaire
California
Loren
Silverado c10
This is the filter I’m using, it’s a quart filter. Not sold on Delco parts as of late, China…….? From the information ill be ordering a 51061 next time, thanks!
SirRobyn0
Not to steel the thread but if I may ask a sub-question, to Scott's question. The WIX 51794 AKA big filter, anyone find an inexpensive source for these? I run the 51061's but the $17 or higher price on the 51794's have kept me from running them. Thanks.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
350, 350, 350, 350, 350, 350
That's better than oreillys. I think it was $22-$23, I'm about to buy another one shortly, need an oil change. I run em for the extra filtration and the extra quart capacity.
For everyone thinking about switching to the big filter, you get almost a perfect extra quart of capacity just by using the big filter.
Keep in mind this filter will also slightly affect your oil pressure, i saw slightly lower pressure across the range, mainly at idle, after going to the big filter. This may not be true for every engine, but it's something to consider.
PrairieDrifter
North Dakota
Mason
84,79,77,76,70,48
Also in reply to the first post, I would leave the used wix I had on until I could get another, over using a fram filter. ANY day.
SirRobyn0
Interesting on the oil pressure thing. I wonder why that would occur, perhaps oil flows better though the larger filters IDK. BTW the price I mentioned was from a wholesale supplier, but I just looked and I don't know why I hadn't thought to before. http://www.discountfleetsupply.com/ If you don't mind getting a case of 12, it's $104 + shipping which to my address is $46!! so that's $150, which works out to $12.50 a filter.... I have used them in the past so they are a legit company, I just don't know why I never thought to look up that filter there.
I agree with that. Though I'd accept a Microgard, NAPA or Carquest branded filter, who are all made by Wix, but who knows if they are made to the same standards, so my preferance is an actual Wix filter and for anyone who doesn't know O'Rielly's is a Wix distributor.
midwest
Indiana
Scott
I looked today. The WIX on Amazon is $9.00 and they are $13.00 at my local Oreily's.
squaredeal91
Cave junction Oregon
Greg bush
1991 SB
5.9 Cummins 12 valve
Somewhat off topic. on My 99 suburban I converted to a regular spin on filter in original location. A regular filter is too tall to clear the ifs front yoke. I found a filter a little shorter. Parts master #1069. Wix/ or Napa # is 51069. And I've been getting mine from NAPA for years now. If space is limited these numbers are good references.
oldretiredafguy
N. Texas
1988, 1988, 1991, 1983
350, 350, 350, 350
FWIW: The Delco PN# for their 2 qt filter is PF932. Had the local Advance Auto store order in a half dozen for me. Don't remember the unit cost, but not enough to break the bank. It is stickered with a "Product of USA" label.
Jleopard77
