SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- C20
So I'm about to replace my exhaust systems. I like what I have quite a bit, but it's falling apart. Unfortunately I'm on a tight budget as I need to do rear brakes on the truck and bunch of front end work on the wife's minivan. So I need to replace it as cheaply as possible.
So what I currently have is the stock Y-pipe, running into a 3" cat, a 3"mid-pipe to a Walker FX muffler with dual outlets I think the outlets are 2" each. I've been very happy with this setup, but the cat and mid-pipe came to me used 4 or so years ago. The cat is obviously failing at this point, the mid pipe is paper thin, the muffler and tail pipes have holes. I cannot currently afford to replace this system with like products and as much as I tend to like good flowing single exhaust I'd like to switch it up and go to duals, just to see how I like it on the truck, but I have to make sure they aren't to loud or I'll hate it.
I'm going with an inexpensive dual kit Dynamax #89006, I can get it for $139 so it's affordable 2 1/4" dual pipes I can get it for $139. But there are a couple of things I do not like about this, there will be not an H-pipe or cats, but that's just for now. Once I get past Thanksgiving I should have money for a pair of high flow cats and later on I'll put an H-pipe in it. Dynamax kit should arrive on Monday.
For mufflers I was going to do cheap Thrush turbos cost is $20 each. I've actually ordered and already received them, but I'm having second thoughts. I'm thinking of returning them and ordering a pair of Walker soundfx #17845, those are the OEM equivalent for dual exhaust. But they are $45 each. The thrush units are $40 total and the Walkers would be $90 each. Saving the $50 is appealing, but not if I'm gonna hate the cheapies. The walker is a 20" muffler body, where as the Thrush is 14".
So my first question, is anyone running thrush turbos in a dual setup on a SBC and want to give an opinion on how loud they are? Even better if you happen to have audio or video of your truck running with those mufflers.
Thanks.
Thanks.
