WTB 454 Serpentine Accessory Brackets
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
When you change from "V" belts to a serpentine belt, you need to swap the water pump too. Not just the pulley, if you are spinning it backwards.
Yes, I understand that.
Thank you for reminding me.
I already have a new reverse rotation water pump.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Sure, will do.
This was out of an RV. Have a serp style belt going from water pump to alternator, then v belts on the AC, power Steering, smog, and hydraulic pump.
Hello and once again thank you so much for checking!!
Unfortunately I'm working on a full serpentine unit, not the hybrid with the v-belts belts and one grooved belt.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
To the Team,
Anyone here have dealings with:
1low4x4
or
saucekid ?
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Oh okay. Figured none of the junk i took yesterday would be of any use, but figured id mention it anyway.
This is the bracket anyway. Totally goofy looking.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Actually I believe that's a very rare part.
Very very hard to find if someone needs it.
But I already started with the full serpentine system I'm just missing those three little brackets.
I'm sorry to make you go through all that trouble for nothing.
Thank you very much!
If you need help finding the part number for that let me know.
You could probably list it on eBay for a good price.
AyWoSch Motors
The Parts Guy
New Mexico
Ayden
K1500 Sierra
350ci V8
Oh it was no big deal, i just got it yesterday, was just sitting in my shop.
Thats really cool, didn't know that was rare. Good to know, thanks.
Ill keep an eye out for the one you need.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Many thanks!
To the Team,
1low4x4
or
saucekid ?
I've know 1low4x4 for years. He use to be on this site. He is a good guy.
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
These are the two parts I'm still looking for:
These are parts for the early BBC serpentine setup for an '88 to '91 BBC squarebody found in 3/4 ton Suburbans and 1 ton crew cab squarebodies (R/V 2500 and 3500's). Also, this setup was used in the next body style '88-'93 C/K models.
The first part is the rear alternator bracket. It's on the left or driver's side of the engine behind the alternator. It attaches from the intake manifold forward to the back of the alternator. GM part number 14103109 or 10230229.
The second one is one of two tubular, rear AC compressor braces.
There's two tubular braces that go from the intake manifold, on the right or passenger side of the engine, to the back of the AC compressor. GM part number is 10085786. This tubular brace has a nut welded on one end.
Please see attached pictures:
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Pictures continued
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Still looking for this big block Chevy, 454, serpentine alternator bracket:
See pic
mrdap
USA
C/K_Lover
C20/K30/V15/V2500
Still looking for this big block serpentine alternator bracket
SMC2224
