Pre-molded rubber fuel lines
JimVG
Gig Harbor, WA
Hello,
Does anyone know of a source for the two pre-molded rubber fuel lines that connect the hard lines to the fuel pump on a 1978 K10 5.7/350? I have found the “sidewinder” universal sections, but these are single plane bends. The factory hoses are dual plane bends (horizontal & vertical).
I know that I can simply cut the single plane bent hose, use a hard line as a splice, and rotate a bent section 90°. This will work if no direct replacements are available.
Pic attached.
Thanks!
PrairieDrifter
North Dakota
Mason
350, 350, 350, 350, 350
They aren't available. As far as I know they still aren't but I'm not sure, but they haven't been available for as long as I can remember.
PrairieDrifter
North Dakota
Mason
Those sidewinder hoses would be perfect, I've had them in my Amazon list for awhile.
JimVG
Gig Harbor, WA
Thanks for the info.
SMC2224
