CheemsK1500
- Jun 3, 2022
- Texas
- Paul
- K1500
On top of a mid '80s 305, I have a mid '70s q jet With a divorced choke (the choke isn't hooked up at the moment.).
I have confirmed that the mechanical fuel pump works, but the truck won't start unless I dump gas in the carb first. Within a few hours everything in the carb leaks back into the tank, and I have to prime the carb again. Anything obvious I should check before attacking every fuel and vacuum line? Thanks.
