57 Chevy Truck Do Over
Madhorn
AR-Arkansas
Ken
5.3/NV4500/NP205/4:56 gear/35in tires
Made some progress on the front front light harness. Head lights are complete. Waiting on new turn signal light assemblies to finish up front. Also had time to run the tail light harness to the rear of the truck.
Madhorn
AR-Arkansas
Ken
Finished up the front lights.
Carb'ed Vortec 350
Always wanted a 4x4 version of a 55-57
Same here. They look way cooler than any other truck. Saw one a couple weeks ago, probably had a 4 inch lift, 35's, it was cool to see.
Carb'ed Vortec 350
Liking the rewire job. And that patch panel next to the brake booster turned out great.
Madhorn
AR-Arkansas
Ken
Madhorn
AR-Arkansas
Ken
wiring is just about complete, new fuel tank installed and A/C bracket modified for vortex heads. Getting really close to cranking it up.
Madhorn
AR-Arkansas
Ken
oil changed and pump primed. Close to cranking it.
Madhorn
AR-Arkansas
Ken
started right up and ran great!! Need to replace rear spring shackles before driving it.
Madhorn
AR-Arkansas
Ken
Replacing all the rear spring pins. Yes one seized in the mount.
Madhorn
AR-Arkansas
Ken
rear spring mounts removed to press out old bushings. No rubber bushings in this set up.
Madhorn
AR-Arkansas
Ken
The rivets attaching the mounts to the frame were a booger to get out. Not much space to swing a hammer. Will replace them grade 8 bolts.
idahovette
Weiser Idaho
Perry
K20-K10
UH.....maybe NOT so easy peasy~!!! That is tight back there!!
Madhorn
AR-Arkansas
Ken
I purchased an air hammer thinking it would zip the river heads off. Nope, had to cut the river heads off with die grinder, then beat the rest of the rivet out with a hammer and punch.
adhkjashda
