SirRobyn0
- Dec 6, 2019
- In the woods in Western Washington
- Rob
- C20
I would say this is the place. If you want more input from more of the members you might want to post your problem in engine performance or ask an admin to move this thread.I've replaced everything (fuel filter, pump ) and those sensors. Same issue. Even after disconnecting and reconnecting battery.
Sprayed all of under the hood with starter fluid to search for vacuum leaks, didn't find any. I'm checking fuel pressure next "just because".
Running a lean condition, definite power issues/won't get above 35 at best.
Any forums you suggest I take this to for expert advice, or is this the place?
