- Aug 3, 2010
- Usually not in Ohio
- Andy
- '77, '78, '79, '84, '88
- K5 thru K30
Well I ended up welding nuts to the tops of the studs and getting them out. I'm not convinced it's going to be any better. This picture is it all done and back on its own weight. It's on a jack stand on the driver side by the way.You must be registered for see images attach
Sent from my SM-G970U using Tapatalk
It's not bad, it appears to match the arch of the spring.
What's your tow-in setting at? With 33's or around in there, about 3/16" tow-in is pretty good, when measured from the tread surface. If it's too far off, one direction or another, the steering will dart all over the place when there's bumps in the road. Stiff springs will kind of amplify that too.
