WebMonkey
- Jan 3, 2020
- Missouri Ozarks
- Chris
- K20
hello all.
1985 k20
350 m code engine
4 spd manual
np208
14 bolt semi float rear
i bought this truck from my son, it gets worse every time i go out to the garage to 'work on it'.
first problem i'd like some input on:
1) the transfer case refuses to 'go into' neutral (and therefore not reaching 4 lo either).
the shifter moves well between 2/4 hi.
i move the shifter toward the passenger door and pull down/back.
the shifter moves a small amount but never 'lets go' of the transmission.
i jacked one rear wheel up so i could spin the driveshaft a bit.
didn't help. i've pushed, pulled, rotated etc for a couple days on and off with no luck.
the shifter/case will go right back up/forward to the hi range without trouble.
what should i look for?
transfer case in neutral is important to me as i plan on towing 4 down as i do with my 2005 dodge ram.
2) there is a 'pigtail' coming from the transfer case shifter console and hanging free above the transfer case. 2 conductor locking plug.
any idea what that is for? neutral light or other indicator?
thanks for your time.
1985 k20
350 m code engine
4 spd manual
np208
