6” Rough Country
Jeff Hudak
brideville de
jeff
k20
i have 6 inch rough country and 37s, im 86 inches, or 7 foot 2 to top of cab
Jeff Hudak
brideville de
jeff
k20
i have a 6 inch rough country lift and 37s, mine is 86 inches top of cab
bft305
ME
Ben
My K20 has a 6” BDS all spring lift kit and with street tires (32”) it will just clear getting into my garage 7’ door. With my 37” swampers I would say about 7’1” - 7’2”.
AMERICANBADASS
EAGLE CREEK
JESSE
Just a follow up, the top of cab ended up being 7’-2”. That’s 6” Rough Country, with 37’s. I was going to do an add a leaf, but chose to do front and rear springs.
Other than a few loose ends to finish, it’s turning out really nice! Thank you everyone for the input
Arkansas_V8
Proud Redneck
Springdale, Arkansas
Brent
V20 Suburban
Looking great.
hoagster
California
K10, 1500
5.3l
Maybe ORD measures "differently" for Suburbans/Blazers. @colonel mustard has an awesome Blazer with a 6" ORD lift... his blazer:
I believe he is on 35s here. Notice how the tires are almost completely out of the wheel well. If I remember right his is 5" taller than mine- so that would be 7'2" or so.
What wheel brand are those?
colonel mustard
louisville ky
steven
k5 blazer
Thanks for the shout out and compliments !!!!
It is a 6” ORD lift on 35” tires. The rims were 15x12. I have since swapped the rims for steel 15x10. Much much better.
FYI.
ORD does not measure the lifts by top of can measurements. The measure from the bottom of the bump stop bracket (front) to the top of the axle tube.
Either way 6” custom ORD spring and 35” tires ..... you will still rub on full flex.
Cheers
hoagster
California
K10, 1500
5.3l
FYI.
Cheers
what brand are your wheels?
colonel mustard
louisville ky
steven
k5 blazer
There was a quote but nothing written ?? Typo ??
michaelmarine53
