Toolbox lights
83kid
Massachusettes
Hi,
So my toolbox is impossible to see in without a light at night, and i want to light it up - but not just on a switch.
I want it to be so that these lights can be on anytime i want, wether or not the truck or headlights are on. They'll be LED's im assuming so power consumption im not concerned with if its draining the battery.
I was thinking use a door jamb switch to wire these up so that when you open the toolbox, the lights go on, and when you close it they shut off.
What lights would you reccomend for this? White colored for sure, and i was thinking maybe those LED strips that you can make different lengths, and have them tucked under the edge of the inside of the toolbox
What do you all think?
350runner
tx
Ceasar
I'd like to see how you mount the switch :) this would be interesting.
chengny
What style tool box do you have?
83kid
Massachusettes
I was thinking taking a little bracket and mounting the switch in the corner on the little opening (inside the toolbox) that goes over the bedsides, and having it high enough so that when you lock it, itll depress the switch.
And, i have a common kind, not sure what it would be called, its a husky just going across right behind the cab, from left to right
And, for lights, im not gonna really have to drill holes anyways. Just 1, and if i want i can probably find a small grommet so it doesn't leak any water through. But, i was thinking the LED strips so you wont really see them at all, but they'll light it up good
ScottyB
Whatcom County, Washington
Scott
phantom
2 squirrels
I'd use a magnetic switch rather than a plunger type. You don't have to make contact so your tolerances don't have to be so tight.
alex7915
