ChuckN
- Nov 8, 2022
- Bellinham, WA
- Chad
- C10
Well I MAY have found an issue. I pulled the distributor, and connected the ground wire to the ground on the battery, positive wire to the battery wire, and put the test light to the C terminal/ positive battery post and rotated the distributor. The test light barely lights up if it does at all. Something is definitely awry with the distributor.
