Dropping my Stock '74 Stepper - Need Advice
jpatters13
Tampa, FL
James
C10 Custom Deluxe
I fully restored a 74 step side that I now want to drop the stance. I want to run the stock rally wheels. I have a set of four 15x8's. I am thinking about a 2.5" drop spindle up front with a 5" axle flip in the rear to get a level stance. I don't want to cut the bed or notch the frame. I need advice on parts but especially tires. I want to run BF Goodrich Radial T/A's. Need the best fit for a fatty muscle look that won't rub. I am willing to pick up a set of 15x10 aftermarkets for the back. The only ones I can find through JEG's and other places have a 5" rear offset (basically a centered wheel). Some places tell me unless I do a 5.5" back spacing it will rub the step fender when going over bumps. All advice welcomed.
78C10BigTen
pennsylvannia
C10 BIG TEN
I can't help with the wheel and tires specs, still a newb to the square body scene, but hot damn that is a beautiful rig! Can't wait to see how it turns out!
I agree! Shes a looker! My fave square combo, round eye stepper!
Keith Seymore
Motor City
Keith Seymore
4.3L
Cut 2 coils in front for 4" drop; relocated spring hangers in rear and removed a leaf for about 6" in rear. Total cost was about $1.38 for grade 8 bolts and nuts plus front end alignment.
Factory tire/wheel setup is LR60-15 Goodyears on the 15x7 aluminum wheel.
K
Finkaire
Finkaire
California
Loren
Silverado c10
I’m in the same boat. I ordered the truck with heavy suspension. Being a little (a lot) older I would like a softer suspension. The fronts after 180k are soft enough. Contemplating re-arching the rears to level out and soften the rear. I am running 275/60/15’s on the stock ralllys. On the forum guys are running and recommending 255/70/15’s. I think leveling out with taller tires might fill the bill. Let me know what you think. After keeping the truck bone stock 43 years, resisting any mods other than the stereo, I hesitate in actually lowering it.
WFO
Texas Panhandle
I think your truck would be perfect with the currant stance, and just a little bit taller tires.
This was 2.5” spindles with 1 coil cut for about 4.5” up front. 6” flip kit in the back. 15x8s all around with 235/75/15s. It rubbed pretty good up front. Had I kept the rallies, I was gonna do a 245/60 and 275/60 combo
jpatters13
Tampa, FL
James
C10 Custom Deluxe
Thanks. I've gone back and forth about what to do and how far to drop it and I just couldn't land on something I'd be happy with. So I just ordered a set of 4 BF Goodrich Radial T/A 265/60/15's to fill out the stance a little better and am going to leave it where it is for now.
Thanks for the input.
JamesSam
VA
Sam
Silverado V10
5.7 L 350 v8
You have a beautiful truck! Something about the early round eyed Squares with stepsides is really good looking. Whatever you do with it you have a sweet rig.
It will look really badass with a drop and your ralleyes, like @Keith Seymore 's stepper.
Scruffy49
Law Enforcement Navy
Rosemark TN
Jeff
C10 swb
4.3L
That’s why I’m keeping my stock 15x6 rallies up front, with a 215/70 or 205/70 to match the rear 15x8 with 255/70 or 285/70 rears. Lucked into a friend wanting to slam her late father’s round eye, willing to do some wheel trading. Hopefully doing the physical swap tomorrow or Monday.
85 red GMC
SW Florida
Bradley
K1500
The height stance for your truck looks about right for factory 4WD. If it is a 2WD, you might want to lower it a bit but I cannot tell you how. My 1985 GMC 4WD step side (seen in my profilie picture) is a fan favorite but I would like to sell it to get another classic car with more room to take friends to car shows or carry car show gear (I never haul anything in the bed for fear of damage) Step side by 1985 was fairly rare. I grew up around my grandfather's dealership. In the 60's and early 70's, the step side was the norm
duncan_schawalder
