Turbo4whl
Downingtown, PA
Wayne
My buddy hasn't gone through much yet but I spotted these two while at their house yesterday and he told me I could have them. An old Mac long reach double open end wrench
Hey Zach, Those long thin wrenches are tappet wrenches. Made thin to adjust valves on old solid lifters on a running (inline) engine. You will not find them useful if you try using them on say, a rusty water pump bolt.
78C10BigTen
pennsylvannia
C10 BIG TEN
Thanks for learnin me Wayne!
CalSgt
CA
Casey
Chevy K-10 Custom Deluxe
New Miller Digital Infinity welding hood!
“Used” on eBay for a good deal but it had never been welded with
And a little TIG practice today
Like my old slant six
Very cool, thanks for the insight! I guess that means this wrench is probably from the 40s or older maybe?
Camar068
Air Force Supporting Member
10 yrs Air Force
Installed a vertical powerstrip on the corner of the wall.
Marine Corps Moderator
Got a inner axle seal installation tool. Not a tool I'll use all the time, just nice to have it in the arsenal.
nvrenuf
Mobile, Al.
Like a good flaring tool, don’t hardly use it but when you need it that thing’s worth it’s weight in gold.
A little tip for those that don't know. If you buy a flaring tool you can buy the long preterminated lines from the parts store. Cut off one flare, slip on your ends if they are different and re flare 1 end. Save the other cut off section for another use.This way they are the correct length, the correct ends and good easily attainable material in my opinion.
1STLS1
West Phoenix AZ
MIchael
Scored these this past week.
55gallon drum dolly, brand new $35.00
Rigid Floor Drill Press $93.00
I missed the handle on the chop saw was broken and ended up throwing it in their dumpster but I think the welding table on wheels was worth $75.00. Couldn't build it for that. The caster wheels were worth twice that. The top is reinforced with angle iron, it looks like it will take anything I can throw at it or on it.
I will most likely never use this but always wanted on, an arbor press. Good for bushings. bearings and races. That was around $170
legopnuematic
Licensed Junk Dealer
MO
Spencer
Nice score on the press! Is it a Dake?
Looks like a Dayton.
Looks like someone gave it the onions to split the daisy wheel in two.
WFarm
Central Virginia
K5 Blazer
Wife got me an early Fathers Day tool, a topside creeper to reach those hard to get to places. Will be great when I need to install my intake and distributor when the intake gets back. In the meantime she certainly seems to like it! :D
Joestreml
