- Jul 3, 2012
- Right where I am
- Bagoomba
- 81-C20 Silverado Camper Special-TH400-4.10s
- Carb'ed Vortec 350
Yep, making sure the engine is at its maximum vacuum at the desired cruise rpms means it's in the sweet spot of the powerband. That is achieved by having the correct engine internals, exhaust pipe size, fuel delivery, etc.With a more or less stock driveline I’m not sure you’d see much for gains (strictly mpg, not cost of regearing, etc). 3.42 to 4.10 (same tire size) you’d be about 550 rpm difference.
There are tons of factors, both vehicle and environmental that contribute to fuel economy, far beyond engine rpm at cruise. Lower rpm doesn’t necessarily mean better mpg.
I have a cowroker that has an 81 stepside. It was a single exhaust truck, and he changed it to 3 inch duals. The fuel economy tanked on it, and he couldn't get it to pass emissions. Had to do a bunch of back and forth with the referee to finally get it to pass emissions, but the fuel economy is still way less than it was with single exhaust.
