Oil pressure sensor?
geauxnow
DFW
V1500 Chev Suburban
Why is pretty green coolant the only fluid draining when i remove this oil pressure transmitter?
xm20k
Girard, Ohio
Because it's in the block drain. Also, that's a knock sensor not a temp or pressure sender.
Oil pressure is directly above the oil filter on the side of the block. Or at the rear of the block behind the intake in the China wall next to the distributor.
The top one pictured is for the light the big can looking one in the lower pic is for the gauge.
Because that is the knock sensor,screwed into the block drain. Factory starting around 1981
geauxnow
DFW
V1500 Chev Suburban
Oh yeah s i knew that was knock. Getting myself confused. Im replacing factory guages w a glowshift set. I can use the can one by the dist? Need to replace the original w ome provided by glowshift
xm20k
Girard, Ohio
You can but you might need to use an angled fitting to clear the distributor.
You can use the one by the distributor or the one above the oil filter.
geauxnow
DFW
V1500 Chev Suburban
Followup question. Havent found the one by the oil filter but i do have a 3/8 plug w a squared center. That is neither 3/8 ratchet or 1/4. How do you get that f out?
gmbellew
Kansas city
glen
suburban 1500
my 1990 burb has a combo oil pressure sensor and and fuel pump bypass all in one behind the distributor. I'd guess your 89 is the same.
I think i remember somebody doing a write up about the Dakota digital gauges and adding an oil pressure sensor for the gauge by the filter. might have been at the plug. search it up.
Turbo4whl
Downingtown, PA
Wayne
Between 1/4" and 3/8" is 5/16". Get a piece 5/16" key stock.
Grainger, NAPA and others have it. Hacksaw a piece off and use a 12 point socket or open wrench. You can also buy female square sockets. The key stock works like an allen socket.
Right above the oil filter
Frankenchevy
Proverbs 16:18
USA
Square
CUCV
Small
I just took a grinder to a spare 3/8 ratchet extension.
geauxnow
DFW
V1500 Chev Suburban
Mine does not. Only the 2wire. Strange because my guage reads but cannot locate the device.
workinman789
