1985 C20 6.2 diesel A/C repair
Craig Nedrow
NADAR UNDER THE RADAR
Washington State
1973 (have two), 1985
K10, K20, C20
350, 454, 6.2 Detroit
Bought this truck with Non working A/C system. There was no belt for the compressor, but have since bought one. I need to diagnose the system, and thought I would hook up the belt and see what happens. All stock components presently. A/C compressors turns freely. I want to do this so, 1) see if the compressor clutch works. 2) see if the system will blow some cold air. From there I can start diagnosing the system. Is this the right procedure? School me.
Edelbrock
Earth
Grumba
K5 Blazer
Many times people remove the belt to get better fuel mileage, especially if they never use the A/C.
I would:
Put belt on, and then turn the controls to max A/C (engine running).
If the compressor "clicks" on and continues to run, then the system is fine and you are good to go.
If it doesn't kick on, check to see if you have 12+ at the wire connected near the front of the compressor (near the pump clutch).
If it has power there, but the pump clutch doesn't engage then you need to adjust the pump clutch clearance.
If there is no power there, then you probably have low pressure in the system.
The power to the system goes basically like this:
Power to dash switch, to low pressure switch to high pressure switch, to the electromagnet on the compressor. If the pressure is too low, then power won't make it past that switch. If the pressure is too high then the power wont make it past that switch. So if the switch is on, and the pressure is in the correct range, and the pump clutch is adjusted properly and in good working order, then you have good working A/C.
As a test on the pump (compressor), you can run a jumper wire from the + battery terminal to the terminal on the pump.
Warning: DO NOT run your A/C system with a jumper wire for regular use. This is only a test to see if the pump will kick on and rotate. Bypassing the pressure switches can cause damage to the system due to low coolant/oil, or even worse you can over pressure the system and cause a high pressure leak that could spray Freon and a find mist of oil into the engine bay that could ignite. (the oil burns, not the Freon)
As for recharging the system, every area has its own laws and regulations. You may be able to buy R134A Freon in your area in small cans, or you may not. But you can't buy R12 at any store in the USA. Some people cross a border into another state or country to buy Freon, and other people buy it private party on Craigslist or FB Marketplace. Refilling the system is very easy. Takes about 10 minutes and is just slightly more complicated than airing up a tire. Done it successfully many times on all different kinds of vehicles with R12 and 134A. The cost to refill the system is $10 to $30 depending on where you get the Freon and oil. The refill hose usually comes with the can, but if it doesn't - its maybe $5 to $10 on Amazon.
Some people will certainly disagree with everything I said. They will say that you need to have the system professionally inspected, have the system purged with special equipment to get all the air and moisture out of the system, use special equipment to measure the hi pressure side and low pressure side simultaneously while filling the system, add the exact amount of coolant and oil, etc etc (very expensive).
Only you can decide what the best direction to go is.
If you do not vacuum the system and there is air in it,your system will not cool as well as it should,but more importantly won't last long. The moisture creates an acid and rots the system from the inside out. So WOW you saved x dollars by not evacuating the system,that's awesome. Until the condenser,evaporator,compressor,and all hard lines need to be replaced. A vacuum pump is so freaking cheap. Even free if your handy and have some scrounging skills. Google it, consequences of not evacuating automotive AC. I learned the stuff in my automotive AC classes late 90s early 00s can't possibly remember it all. Remember enough to just do it right.
legopnuematic
Licensed Junk Dealer
MO
Spencer
I would first get a set of manifold gauges (and a vacuum pump) hook onto the high and low pressure ports.
If you have pressure in the system, then you should be able to install belt and move the selector into an A/C position and see if it will cycle. (Someone correct me if I’m wrong here) Squares should be a clutch cycling system, so if the pressure is below what’s needed for the switch it won’t engage the compressor.
If you don’t have pressure in the system, you can use nitrogen to fill the system and check for leaks. Or if you don’t have nitrogen hanging around, I’ve used shop air and put 100psi in the system. Shop air can introduce contaminants and moisture, so it must have a vacuum pulled to remove and boil all that out.
With it pressurized you can check for leaks, both audibly and with some soapy water at connections. If you have leaks replace appropriate seals/components/hoses that are leaking and then test again. The receiver/dryer/filter should be replaced anytime the system is opened. The oil in the system will also need to be replaced/replenished if parts have been changed. The appropriate amounts should be in the service manual.
Let it stand for an hour under pressure and make sure it holds pressure then hook the vacuum pump up and let it draw a vacuum for 30 minutes to an hour. Let stand again and see if vacuum drops, then run for another hour (longer is fine).
Then you can charge the system. Have a small scale and know how much the system takes (and correct if going from r12 to 134a).
This is the cliff notes version, but sort of the basic process to work through. I did my Dodge a couple months ago and it works great. Yesterday was 90° outside and I get 40° out of the vents.
Craig Nedrow
Washington State
K10, K20, C20
Thanks everyone, I am looking at this kit, think it has everything I need to work on basic system. LOOKING FOR ADVICE B-4 purchasing. Thank's
legopnuematic
MO
Spencer
Craig, it looks like your picture/link didn’t attach.
wildshot27
