Edelbrock
- Mar 28, 2025
- Earth
- Grumba
- K5 Blazer
Anyone ever tried to use one of these? I have not seen them before. Ran across one on a Marketplace listing.
As opposed to a blower mounted under the carb, this looks like a supercharger setup using a carb.
Rather than using a belt drive or exhaust drive system to pressurize the intake, I wounder if you could use one way flapper valve in the intake. Then put a compressed air line between the flapper and the carb. So you could use a pump to store up compressed air, and then hit the "turbo" button and get maybe 10 seconds of boost for a hard acceleration / drag race.
Probably would not work, but I would be interested in what you might have to say if you have any experience using these enclosures.
