El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
Change of Subject:
I didn't wanna start a whole other thread for this question: I replaced my old fuel tilter with a new one because it leaked. It still leaks... any idears?
I just don't like how everything has go to the ground. 95% of everything they do gets lowered. And worse they get some good cars and change everything about them, when they could be great restoration to original projects. Then he wonders why he loses his ass everytime he goes to an auction.
83swb
CT
Hunter
83'
350/th350
They need to build variety. Everything doesn't need to be pro touring.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
I do have to agree with ya there. EVERYTHING gets lowered, different engine, seats recovered and paint
MrMarty51
Eastern Montana
Martin
Change of Subject:
O-rings ???? the ones on the fuel piping, where it shoves into the filter.
Maby, a cracked fuel pipe, where the flange is and the flare nut rests against it.
El Camino Man
SO IL
JP
R30 Scottsdale
6.2L
That sounds uneasy to fix lol
Finished up the Harmonic Balancer Install job and the New/USED 4 core radiator install.
This old 4 core radiator I took out, has a small seam leak at the tank. Anyone know if radiator shops are still in bidness? I'd like to keep a REAL radiator in all my trucks. So I'd like to get this one to radiator a shop, have it cleaned, rod out the cores, re weld all the tanks and make it like new again. I think most radiator shops have bellied up with it being common cars having plastic radiators now. Another thing radiator shops were good for was taking your gas tank to them and they'd boil it out and get all the **** out of the tank.
MrMarty51
Eastern Montana
Martin
Brass wire brush, a jug of solder flux, a roll of solid core solder and Your acy/oxy torch and Your good to go.
place a wet rag, outside of where You want to sloder, to act as a heat dam and keep another soaked rag in the bucket in case things begin to get too warm. Heat the area, needing repair, with just enough heat to make the solder flow good.
I`ve done it so, I know You candoit too. I have soldered hose connectors back in and soldered seams. It`s kind of scarey at first but, You`ll get over that.
Main thing is to not allow the tank to get so warm that the tubes begin to let go, I`ve had to resolder several of those, that was about the first time I ever tried a radiator repair.
Sometimes, if it is not cold outside, I will take the tools, radiator and torch outside and let the garden hose run water over the areas I dont want unsoldered. :boxed::rotflmao:
travisr1988
Cedar Park, Texas
Travis
C20 Silverado
I replaced the upper radiator hose, thermostat (195*), and thermostat housing because the housing was leaking, the hose was swollen and I suspected the thermostat was the reason my temp never gets above 160* unless I'm out of coolant. Well, it still leaks, and the new 195* tstat didn't change anything...so now I need an intake as it is likely the reason the tstat leaks. Any ideas on temp issue?
WVscottsdale
West by God Virginia
Daniel
Scottsdale K10
350 bored .040 over
Its not on my square body but I got a good deal on a swap brake parts for a SM465 and all the linkage pedals and everything to switch my auto to a manual if the auto goes out
MrMarty51
Eastern Montana
Martin
Getting the wiring figured out, going from a solenoid tank switching valve to a motor driven.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Picked up some more fittings for my transmission cooler install, and working on building a tubing straightener. Would you believe they want $200 for a bloody tubing straightener? All it is, is 5 pulleys with bearing centers, and 2 of them adjust up and down. TWO HUNDRED FOR THAT?!
I washed mine and took her for a short spin
You'd think for that much they could at least wipe the blood off of it. :shrug:
aaron06
