MrMarty51
Eastern Montana
Martin
No, 79 is a Race Track Pattern 32 spline. Round Pattern didn't start till like late 85 or 86.
What you have there is also a Race Track pattern, but in a 27 spline.
AAAHHHHhhhh, so that is why that kit comes with the trans/205 mount and a bunch of other stuff including, the input shaft for the 205.
And so, if there is such a thing as, a 205 coupled to a 400 trans. of about 85 or older, I then could have all it`d take to hook them together, trans to 205/mount adapter with the 205 input shaft. anything else ???
I`m getting bearings/seals installed into housings today.
Danged rear output shaft has one of the pins for the thrust washer broke off flush with the shaft and the other pin was`nt even in there. fugggg, now I`ll be drilling an 1/8th inch hole into the shaft and then making a set of pins. should work though.
Driver4r
Nebraska
Trevor
k10,c20
mechanic said the c20 was out of time, he set timing truck runs great a lot of power. i shut it off wouldn't start cooled off started hard, never been a problem. i talked with the mechanic,said he had to advance timing to get it to run well ,said to pump the gas pedal to get cooler gas? he drag races said his mustang was the same way.any thoughts thanks in advance
Could also be a starter thats getting warn out. After i got my truck we advanced the dist. and she was a BITCH to start. I ended up putting on a remaned starter and now she starts really good.
philjafo
everywhere
phil
k20 scottsdale
350/sm465/np205/d44/corp14
May want to verify the mechanical advance is moving freely.
foamypirate
Central TX
Jake (Mr. Wilson)
El Camino, baby!
5.3L/4L60E
Transferred 5 lbs of its grease onto myself while tearing down the front suspension.
WVscottsdale
West by God Virginia
Daniel
Scottsdale K10
350 bored .040 over
3/4 ton axles 4 inch lift rebuilt trans and rear wheel disc conversion and tags lol minor crap. Now tuning the engine cause old trans issues and she has been sitting for a while.
chubble
Eastern, NC
Custom Deluxe K10
Tinted my glass to 20%...Did a real bad job cuz of cheap tint and a dull blade though. Still better than nothing for now. I'll prolly do the front windows one night this week.
Anyone have any advice for tinting the vent windows?
bluex
Spartanburg SC
C15
Dropped the lower control arms off to have them reinforced under the bushings. Swapped steering wheels, and finished up the front suspension tear down. Waiting on my offset upper shafts to start reassembly, one came today right part # on the box regular straight shaft in the box though :(
bluex
Spartanburg SC
C15
Woo Hoo, Kinky sex with Mama to be tonight !!!
If his wife is anything like mine the first thing she said to him after he came in the house was "you stink" :(
mine too :sad72: she won't let me touch her with my greasy hands until I've washed up :(
SlickGTP
Houston, TX
:lol: mine does that to me quite often...
Covington, WA
350; 700R4
From my wife the other day: "You look kinda hot all covered with grease in your Carhartts."
My wife likes watching me work and doing all that stuff but I still can't touch her til I'm cleaned back up. Doesn't stop me from smacking her butt when she turns back around, though :D
Snips71
